LabWindows/CVI
Is there a way to disable 64 bit in batch build?
Hi
I upgraded to CVI 2010 and when I select "Check all Debug" to perform a batch build CVI selects debug and debug64 configurations. But I need only the debug configuration without 64 bit. Is there a way to disable the debug64 configuration somehow? I don't want to deselect the debug64 configuration files every time I do a batch build.
Thanks in advance.
(3,373 Views)
for me initially all batch build options are deselected. You can select individual options and don't need to click 'check all debug' .
Is this your question?
(3,371 Views)
Thank you for your answer. I know that I can select individual options. Sometimes I do a batch build of my colleagues big project an the easiest way is to check all debug. Well, if there is no other way to disable the debug64 configuration automatically, I have to do it manually.
(3,368 Views)
I've created a small program which does the job. It's "version 0.1", so use at your own risk 😉
Maybe I will built in some other features which is the original batch builder still missing, like possibility to store custom built sets (only first 5 projects in workspace, all dll's in debug, exe in release config or similiar.)
Feel free to adjust the code to your needs.
Peter
(3,345 Views)
sorry, just found first bug, which is now fixed (did not stop when reached last prj in cws)
(3,341 Views)
