LabWindows/CVI
Is there a way to modify chamfer size on toggle buttons?
I am using LabWindows/CVI 2010 on Windows 7 for a client's application.  Is there a technique to change the chamfer size on a standard toggle button?  I do not see an attribute, or any other settable item, but maybe I missed something.
Thanks.
(4,428 Views)
Hello ryk,
Unfortunately, there isn't an attribute or a setting that allows you to change the angle of the corners (chamfer size) on the toggle button or other button controls (including picture buttons).
This is a predefined appearance setting of various LabWindows/CVI controls.
- Johannes
(4,416 Views)
