LabWindows/CVI
Is there a way to specify the font for OpenDocumentInDefaultViewer function?
Is there a way to specify the font for the call to OpenDocumentInDefaultViewer?
Donna
(3,035 Views)
Hello Donna,
You cannot specify the default font for the OpenDocumentInDefaultViewer call.  This function has the same effect as double–clicking a document in Windows Explorer.  The default viewer will be opened with the default environment settings.  Now if your particular viewer has an API that allows you to change the default font, then you might be able to call this function in CVI before the call to OpenDocumentInDefaultViewer.  Specific information on viewers and available settings would be found on the relevant support website for those vendors.
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,020 Views)
