LabWindows/CVI
Is there a way to view the machine code (assembler) generated by LabWIndows/CVI 6.0.
I need to view the machine code (assembler) generated by LabWindows/CVI 6.0. If there is no way to do this via LabWindows/CVI developement environment? Is there a utility that will generate the assembler code from the object file? I am using Borland compatibility. Do I have to turn on a compiler option to get embedded information in the object file?
(3,847 Views)
Unfortunately it will not be possible to get the assembly code from CVI.  If you have a compiler that can produce the code you should be able to get it by compiling your CVI code in that development environment. You can also suggest this feature to us by giving us feedback.
Apologies and good luck!
Travis M
LabVIEW R&D
(3,819 Views)
Thanks for your help. I am searching for methods that will allow me to view the object file.
(3,813 Views)
Isn't there a way to view assembly code within Visual C++ ?
- If you can import the code (and make it compile under Visual C++ with Measurement Studio), then you can use this Visual C++'s feature.
(3,774 Views)
I do not have Visual C++ installed yet. I will try that as soon as I can.
(3,758 Views)
