LabWindows/CVI
Is there an example code in LabWindows/CVI to transmit and receive data for ENET 232/4?
Is there any example code to read and write to the enet 232/4 in LabWindows? thanks
(3,776 Views)
Trac2,
Once you have your card installed properly, it should show up as any other serial port. The Example Finder in CVI has a couple examples to get started:
regards,
Peter Flores
(3,756 Views)
  Thank you very much!
(3,749 Views)
