LabWindows/CVI
Is there any direct calls for working with RS-232 and RS-485 cards
I want the full version of the code that is used for the direct calls for working with RS-232 and RS-485. Kindly send me the detailed code for interfacing both of these with my computer. I am working with Windows NT,Lab Windows/CVI Version 6.0
(2,890 Views)
Hello
Check out the libraries for RS-232 installed with CVI. You can also use the visa libraries to communcate with these ports. These functions include the documentation that you can access by right-clicking on the function panel.
If you need examples, check out the Serial Instrument Connectivity page. You can application notes and examples about using the serial ports.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(2,890 Views)
