LabWindows/CVI
Is there any easy way to get Seconds from a Date/Time string?
I have 2 strings of the following format that I would like to convert to seconds (since 1900). I need this value to set the t0 on a plot.
Date: "06-30-2014"
Time: "16:06"08"
Is there a CVI function that will do this conversion for me? If not, is there an easy way to do it?
Thanks!
(4,931 Views)
Accepted by topic author Hoof
This code should do what you want:
#include <formatio.h>
#include <ansi_c.h> static time_t calt; static struct tm tm; static char msg[64]; static int yy, mm, dd, hh, mn, ss; strcpy (msg, "06-30-2014 16:06:08");
// Extract component from date/time string Scan (msg, "%d[x]%d[x]%d[x]%d[x]%d[x]%d", &mm, &dd, &yy, &hh, &mn, &ss);
// Transfer components to a tm struct tm.tm_hour = hh; tm.tm_min = mn; tm.tm_sec = ss; tm.tm_year = yy - 1900; tm.tm_mon = mm - 1; tm.tm_mday = dd;
// Obrtain the calendar time calt = 0; calt = mktime (&tm);
(4,923 Views)
Thanks for the help with this.
(4,895 Views)
