In CVI, only the topmost windows can access the system-specific window handle which is NOT settable. Using "CreatStatusBar" API to create a statusbar generates a child panel's window handle which you can do nothing. If you really want to add a windows style statusbar, you can use the ActiveX control "Microsoft StatusBar Control" in mscomctl.ocx which is in the SP4 of Windows2000.
