LabWindows/CVI
Is there anyway to disable the beep on tables?
I am using a table. In the table I super-impose a ring control over the active cell on an EVENT_LEFT_DOUBLE_CLICK to give the table "ring like functionality". The problem is the cell is an indicator type and it gives the annoying beep everytime I double click. I would like to find a way to keep it as an indicator to avoid allowing the user to enter their own values in the cell.
(2,955 Views)
You don't need to put the table control in indicator mode. You just need to "swallow" the EVENT_LEFT_DOUBLE_CLICK to prevent it from going into edit mode. Swallowing the event means returning a positive value (return 1;) instead of 0. See the online help for a discussion of swallowing events.
Best Regards,
Chris Matthews
(2,955 Views)
Best Regards,
Chris Matthews
(2,955 Views)
