LabWindows/CVI
Is there are limit to how many panels can be developed in one .uir for LabWindows/CVI 5.0?
Is it possible to create so many panels in one .uir that the software would not be able to handle?
(2,921 Views)
I'm sure it's possible, but unlikely that you would find the limit. It does have to load in the resource file, but I would imagine 100's if not 1000's of panels could be in the UIR and load on a typical modern machine. Are you having some sort of problem?
Best Regards,
Chris Matthews
(2,921 Views)
Thanks Chris-No problems, but we anticipate expanded follow on work and we wanted to make sure we could handle additional panels, else we would have to do some work arounds. Your answer is exactly what I needed.
(2,921 Views)
