LabWindows/CVI
Is there some driver in CVI for use the instrument LCR Fluke PM6306
My question is
Is there some driver in CVI 7.1  for controling the instrument LCR Fluke PM6306 because I need to do a aplication for this instrument for comunication RS232  for measure diferent components??
if you have some responces please Let'me Know.
My email is Mario.Ku@motorola.com
Thanks to all for your help.
(3,396 Views)
Hi Mario Ku,
a search in the Instrument Driver Network only returned a driver for LabVIEW communicating over the GPIB.
Nevertheless, according to the Programmers Manual (which can be downloaded here) your instrument can be programmed over the serial port with a simple message protocol. I have used this protocol with some Fluke DMMs finding it easy to use. The manual includes also a small BASIC sample program which can be easily ported to CVI and can serve you as a framework to develop your own set of commands for your instrument.
I suggest you to connect initially to the instrument with a simple 3-wire cable without hardware handshaking, which is easy to realize and easier to control in program, switching to a more complex connnection with hardware handshaking in a second time and only in case you absolutely need it.
(3,386 Views)
Thanks a lot Robert.
(3,376 Views)
