LabWindows/CVI
Is windows cvi compatible with windows 10 ioT core?
i would like to run my sw on Raspberry Pi 3 for example
thanks
(3,980 Views)
as you can see here CVI only supports x86 and x64 versions of Windows 10
(3,977 Views)
does Run-Time Module for Linux solve this issue?
thanks
(3,973 Views)
Run-Time Module for Linux most likely will not solve the issue, as there is a list of supported systems for that module too. The specific supported Linux systems are in the article below.
National Instruments Driver and Software Support for Linux Distributions
http://www.ni.com/product-documentation/52786/en/
However, people have been able to find some kinds of workarounds in the forums beforehand. Below is an example.
https://forums.ni.com/t5/LabWindows-CVI/CVI-Linux-Raspbian-Raspberry/td-p/3132267
Best,
Shamik C
(3,922 Views)
