LabWindows/CVI
Issue In loading the .OBJ Files from CVI EXE
Am having a project where mutiple instrument drivers are creted as .obj files.
these .obj files will be consumed dynamically by a CVI EXE using LoadExternalModule().
i have a frequent requirement to change the EXE implemetation which will be released frequently.
but whenever i change the .EXE source code for release its not loading the .OBJ files created previously.
why this is happening , i dont want to re relese my .OBJ every time i change my .EXE.
Please advice!!!
Thanks in advance
-IVI
(4,833 Views)
Hello IVI!
I couldn't reproduce the problem described:
  1. What error code does LoadExternalModule return when it fails to load the .obj files?
  2. Did you also try using LoadExternalModuleEx?
  3. Could you provide more details about the project?
  4. Is it possible for you to provide a minimal project setup which we can also use to reproduce the issue?
  5. What version of CVI are you using?
Thanks!
- Johannes
(4,715 Views)
