LabWindows/CVI
Issues initializing high speed digitizer card
I recently built a new computer for data acquisition.  I didn't have any issues taking a data acquisition program for a high speed digitizer written in LabWindows 8.5 and running it successfully with LabWindows 9.0 on the new machine.  The only issue I encountered was naming the high speed digitizer card in MAX the appropriate resource name expected by the data acquisition program.  Everything ran fine for 4 days.  Today I attempt to run the same program and cannot get it to run.  Debugging the code shows that the device fails to initialize when niScope_init() is called.
In MAX the digitizer card passes a self-test, and I can call up test panels and see a signal input.  I checked the device name to ensure that it matches the resource named expected in the program.  I also reset the device in MAX and then tried to run the acquisition program.  None of these attempts has succeeded.
I can't really find anything that has changed between the last time I ran the program and today.  Has anybody run up against this issue in the past, and is there a solution or suggested further troubleshooting?
(4,102 Views)
Did error checking with a ni Scope error handling function.  The error number returned is -1074134994.  I cannot get the function to write to a char array describing what this error number actually means.
(4,100 Views)
The error code translates to this error message: "Initialization failed in driver DLL".
I used the function niScope_error_message to find out.
Did you try running the NI-Spy while operating the test panels?
NI-Spy can be configured to capture NI-SCOPE library calls, from which you can see how MAX is initialising the card successfully.
Hope this helps,
S. Eren BALCI
IMESTEK
(4,089 Views)
Accepted by topic author Brumfield137
This issue was solved by re-installing the drivers for our high speed digitizer.  I still have no idea why after four days something happened to the original driver installation.
(4,056 Views)
