This is an update to an original posting under VXI...
Fresh load of NT 4 on a Dell GX110. Service Pack 6a. No IE, or other non-base apps. 20G drive with 2G/18G parts. Loaded NIC & video drivers for Dell devices. Loaded Measurement Studio 6.0 (complained when nids.dll didn't register - Data Socket w/o IE?), then 1394/G driver ver 2.1.
When resman sends out the BNOs (it flashes so fast), I get the KMODE_EXCEPTION_NOT_HANDLED blue screen. It always reports that it's in nivxi1394k at offset 116C.
UPDATE>>>>
I can install the 1394 driver prior to MS 6.0 & all is OK. After MS 6.0 is loaded the same BSODs return with the same offset in nivxi1394k.SYS.
When can I expect 6.0.1??
I've also been fighting a BSOD problem
with 5.5.1 when an application exits. These are IRQLs from ntoskrnl.
HHEELLPP!!
