LabWindows/CVI
Kollmorgen AKD modbus or Telnet over ethernet TCP
I'm a beginner using LabWindows CVI. I have a Kollmorgen AKD driver that can communicate via Ethernet using either Telnet or Modbus protocol. To make sure the hardware works, I downloaded the Kollmorgen WorkBench Software onto my laptop and went through the QuickStart guide. I set my laptops address to a static id (192.168.0.100) and then set up the Kollmorgen driver to have a static id of (192.168.0.26) using the two rotary switches (S1 and S2). In this case, I chose 2 and 6. I connected my PC to the driver using the Workbench software and was able to successfully spin the motor ccw and cw. I also was able to move the motor to specific locations (90, -90, 180, etc) in relation to the set 0 position. The Kollmorgen software uses the Telnet protocol.
How would I go about connecting my PC to Kollmorgens AKD driver using Modbus/Telnet via Ethernet on LabWIndows CVI? Is there a modbus library or special functions?
I went to the Modbus website and did not find any examples...
Any help would be much appreciated.
Badra
(4,873 Views)
There are free LabVIEW Modbus libraries, but these are API's built for LabVIEW:
http://zone.ni.com/devzone/cda/epd/p/id/4756
https://decibel.ni.com/content/docs/DOC-30140
There actually is a push to implement Modbus protocol support in CVI, and you can add your thoughts to the discussion here:
http://forums.ni.com/t5/LabWindows-CVI-Idea-Exchange/Implement-Modbus-RTU-TCP-protocol-support/idi-p...
The Idea Exchange forum is used by R&D in order to help implement new features requested by customers in later releases. You can also try using a free C library that does Modbus protocol, since CVI utilizes C code. An example would be libmodbus:
http://libmodbus.org/documentation/
There is also this community example which implements Modbus RTU programming over RS232 in CVI:
https://decibel.ni.com/content/docs/DOC-15734
dK
(4,823 Views)
