LabWindows/CVI
LAB WINDOWS, tcp/ip
I am trying to communicate several PCs whith a server throug the functions
about TCP/IP LabWindows supports. Each client sends 4 buffers with information.
My problem happens even with only one client and it is the following: The
server can sometimes receives all the buffers, but not always. I would like
to know if it is due to the time the server needs to process all the information.
Is there anyway to access to the queue of the operative system where the
buffers are kept? Am I obligued to send only one buffer with all the information?
In that case the buffer would become too long. Is the solution in using multithreadin
even only with one client? I would be very grateful if somebody could help
me. Thank you in avance.
(3,414 Views)
Hello I'm nico from france.
Sory i don't have your answer.
But i have a question.
Do you know where can i find exemple
to use tcp ip with lw cvi
Thanck you , best regars
nico.
e-mail
brice@iat.cnam.fr
(3,414 Views)
I am having the same problem. Was this resolved?
-Rich
(3,414 Views)
