LabWindows/CVI
LABVIEWV.LIB was not called from a LabVIEW process
I'm working toward calling a dll created from a vi in a LabWindows/CVI application. The dll requires an LStrHandle so I'm using code I found here.
static LStrHandle MakeLStrHandle(char * text)
    LStrHandle lvStringHandle;
    lvStringHandle = (LStrHandle)DSNewHandle(sizeof(int32) + strlen(text) * sizeof(char));
    // Empty the buffer
    memset(LStrBuf(*lvStringHandle), '\0', strlen(text));
    // Fill the string buffer with stringData
    sprintf((char*)LStrBuf(*lvStringHandle),"%s", text);
    // Inform the LabVIEW string handle about the size of the stringData
    LStrLen(*lvStringHandle) = strlen(text);
    return(lvStringHandle);
At first it failed to link. I tried adding labview.lib and labviewv.lib and either one allows it to link (What's the difference between them?)
But when I run the program, I get an error creating the DSNewHandle. I get the same type of error regardless of whether I use labview.lib or labviewv.lib.
It looks like I'm not initializing something, but what?
(4,341 Views)
jtdavies,
what is the error you get when calling DSNewHandle()?
Marty H.
(4,320 Views)
I went away for a long weekend, and this morning my problem had disappeared.
So I guess I don't have a problem anymore.
Thanks for looking at it.
John
(4,280 Views)
