LabWindows/CVI
LCVI Starts Up, Then Just Aborts...Help
I've been running LCVI 2009 for a long time.  It's never given me any problems.  Then yesterday, it started acting really strange.  Whenever I try to start it from the Start menu, it briefly displays the startup screen, then just aborts with no message.  The startup screen is visible for about 1 second, and then it just disappears.
And when I try to start it my double-clicking a .prj or .cws file, it does the same thing, but also a Windows error message popup is displayed which says that Windows can't find the file that I just double-clicked.
I uninstalled LCVI and then reinstalled it.  No luck.  Then the head our our MIS department uninstalled and reinstalled, with no luck.
Is there maybe an error log somewhere that I can view that might give me a clue to what is going on?
(3,523 Views)
Hi Chopper77,
This may be due to a known issue and there is a KnowledgeBase article that details a possible solution to this issue. I have included it below for your convenience and I hope this helps!
LabWindows/CVI 2009 Crashes During Startup: http://digital.ni.com/public.nsf/allkb/2CEBB4BE3D4427EA862577650060179F?OpenDocument
Jason D
(3,499 Views)
