LabWindows/CVI
LED constant name doesn't match between popup window and attribute panel
Editing a gui panel (.uir file) in CVI, I double click on an LED and edit its constant name.  The name in the attribute summary panel on the right of the IDE shows the wrong name.  What causes this?  I had copied and pasted other LEDs before editing their names.  It seems like the copy/paste operation has confused CVI.
(4,185 Views)
Hi gstemp,
I may be missing some information to get the full idea of what is happening.  I tried to reproduce what you are seeing but am not getting the same results.
Here is what I did, please let me know how your process differs:
Opened LabWindows/ CVI 2010>>Created New UI Project>>Added new UI>>Placed an LED on Panel.
Here I first verified that by double clicking the LED (round) and changing the Constant Name also changed the Constant Name under Source Code Connection on the attributes pane.
I then copied this LED several times and changed the resulting Constant Names in the same double clicking fashion and observed the corresponding attribute change with it.
So I believe I am seeing expected behavior but it is very possible you are doing something differently than me.
Kyle S
Regional Account Manager
NI
(4,170 Views)
Accepted by topic author gstemp
I was using CVI 10.0.0.  I called support, and the support engineer was able to reproduce the bug on 10.0.0, but not on 10.0.1.  So I upgraded, and the bug is gone.  I think the problem occurred in 10.0.0 when I exceeded 256 LEDs.
(4,166 Views)
Hi gstemp,
That is great to hear you received the support you needed and were able to resolve this issue.
Kyle S
NI
(4,162 Views)
