LabWindows/CVI
LIN Serial Analyzer
i have a LIN Serial Analyser of microchip (Part Number: APGDT001) , and i cant comunicate with it ,I use CVI national instruments LabWindow for this , but i dont find any exemple how can i communicate with it via (CVI national instruments LabWindow).
have any exemple about that ?
(5,350 Views)
Hi corail77,
When you are in CVI, go to Help -> Find examples change for the Search tab and enter "lin" you will see several projects implementing LIN in CVI.
Regards.
(5,301 Views)
hi PEDRO,
i do this but the search it is similar to the "linear",
in my problem i have a LIN Serial Analyzer from microship ,
and i think it's defferent to another ,
i dont find any exemple or any tutorial how i can communicate with it ,
only i find a DLL file contain 600 function
(5,294 Views)
corail77, it seems it doesn't exist a program already made to communicate with this device in specific so you'll need to create the way to communicate to it using the dll you have.
Take a look at this links
http://forums.ni.com/t5/LabVIEW/C-dll-of-static-functions-in-LabVIEW-2011/td-p/1908967
https://forums.ni.com/t5/LabVIEW/APG-LIN-serial-analyzer/td-p/2102338
Forums about this same subject.
(5,287 Views)
thanks Pedro_Rojas ,
but i dont find a solution for this ,
(5,234 Views)
