LabWindows/CVI
LW/CVI 2009 user interface browser missing
Just getting back into LabWindows/CVI after many years. Using 2009 version.
Going through the tutorial located http://www.ni.com/pdf/manuals/373552g.pdf
When I double-click on the.uir file, the panel opens up, but I do not get the User Interface Browser and the Attribute Browser has replaced the Library Browser.
Apparently, this is the default behavior for 2009 contrary to the figures in the tutorial.
How can I get the User Interface Browser to appear and put the Attribute Browser to the right hand side?
(3,121 Views)
The User Interface Browser and Attribute Browser being on the right hand side are both new addtions for LabWindows/CVI 2010. The behavior you're seeing in 2009 is expected and can't be changed.
Kevin B.
(3,107 Views)
Thank you.
(3,104 Views)
