LabWindows/CVI
LabStyle Meter control in CVI6
If I pass a double value to SetCtrlVal() for a numeric slide Meter (lab-style) with Data Type double, it gives a run-time error saying "Invalid argument type: found 'double' expected 'int'"!!
(3,206 Views)
I have never found this error in my projects.
In my experience, every time I have met strange behaviour like that you mentioned I was having control ID problems (I was really addressing a control different from which I intended to), so being in you I'd check carefully the value passed as panel handle and control ID to be sure to address the correct control.
Hope this helps
Roberto
(3,206 Views)
I agree with Roberto. If tracking down the control id proves problematic, I'd suggest the following:
GetCtrlAtttribute (panel, control, ATTT_CTRL_STYLE,&style);
That will tell if the control you're using is even a meter, or if it's something else.
Luis
NI
(3,206 Views)
