LabWindows/CVI
(LabVIEW 8.5.1 error log file: AppEntryPoint.cpp line 74 "LabVIEW 8.5.1" LabVIEW "WindowsXP")
I am writing an algorithm for my IOtech PersonalDaq 3001 and using both the analog output and input channels. I am recording the input to a log file using "Write to Measurement File." Sometimes the program runs fine. Other times it will crash and give me the following error:
I tried doing a search on the forum and was not able to find this code. Do you know what this means and how to resolve it?
(6,016 Views)
Hello AAvedro,
Are you using LabWindows/CVI or LabVIEW?  If you are using LabVIEW you may want to post to the LabVIEW discussion forum.
NickB
(6,010 Views)
Hi AAvedro,
When you get this error, the next time you start LabVIEW you should have an option to either investigate later or investigate now.  If you select investigate now then it will send an email with the error log to National Instruments.  When this happens, an applications engineer will look at the error log and contact you regarding the proper course of action to resolve the problem.  Next time you get the error just follow those steps.  Thanks and have a great day.
Stephen S.
1 Test is worth 1000 expert opinions
(5,987 Views)
I apologize for posting this in the wrong forum. I meant to post it in the LabVIEW forum. I found out I was receiving the error because the data was still being written to a measurement file as the vi was being closed. I will take your advice Stephen in the future. Thank you.
(5,982 Views)
Its not problem AAvedro.  Good luck with you application.
Stephen S.
(5,965 Views)
