LabWindows/CVI
LabVIEW DLL redeclaration errors
Hello all,
I have created a LabVIEW (8.2) DLL that I want to call from LabWindows CVI (8.0).  I have added the required header and library files to my LabWindows project per instructions.  When I attempt to compile I get the type redeclaration errors described elsewhere in other threads.  I have removed all references to the native LabVIEW data types in my DLL VIs.
It is my understanding that I should be able to compile the project with the "extcode.h" commented out in the library header file, but then I get project link errors to the DLL functions when I try to call them.  What's going on?
Slowpoke
Slowpoke
CLAD (believe it or not!), using LabVIEW 8.5
They don't call me "Slowpoke" for nothin'!
(4,979 Views)
Hi Slowpoke,
Can you post a simple version of your VI and C code, so I can check out why this may be happening?
Gavin Fox
Systems Software
(4,953 Views)
Hi Gavin,
Thank you for responding.  I believe I've solved my original problem; I had forgotten to move the .dll file into the same directory as the LabWindows dbg.exe file.  Butn now I have a different problem.
I've included a DAQmx task in my DLL project.  When I build the DLL I add that VI to the list of exported VIs, which gives me a void function with no arguments.  However, when I try to call the function from my LabWindows program it doesn't run the VI.  Does this mean I will have to start the task VI with another VI containing a call by reference node, or is something else the issue?
It might be better if I addressed this issue in another thread.  If so, thanks again!
Slowpoke
Slowpoke
(4,927 Views)
Hi Slowpoke,
I'm not sure why this would be happening from CVI.  You will get faster response in a LabVIEW forum, but I can look into this.
Gavin Fox
Systems Software
(4,910 Views)
Hi Gavin,
I appreciate it but that won't be necessary.  Nothing but a mild case of noobitis (mine).  Smiley Tongue
Thanks!
Slowpoke
Slowpoke
(4,888 Views)
Oops.  Spoke too soon.  I could still use some help on this issue.
Slowpoke
Slowpoke
(4,882 Views)
Nope, still noobitis.  Sorry!
Slowpoke
Slowpoke
(4,859 Views)
