LabWindows/CVI
LabWindows 2006 no ViInt64 ViReal64
So I downloaded some keysight drivers which I am planning on controlling via GPIB.  I am using LabWindows and was not able to build because ViInt64 and ViReal64 are not variable types.  I was able to get it to build by using the following...
//TODO Changed to ViInt32 bit value
//ViStatus _VI_FUNC AgN67xx_viWrite ( ViSession Vi, ViInt64 Count, ViChar Buffer[], ViInt64* ReturnCount );
//ViStatus _VI_FUNC AgN67xx_viRead ( ViSession Vi, ViInt64 BufferSize, ViChar Buffer[], ViInt64* ReturnCount );
ViStatus _VI_FUNC AgN67xx_viWrite ( ViSession Vi, ViInt32 Count, ViChar Buffer[], ViInt32* ReturnCount );
ViStatus _VI_FUNC AgN67xx_viRead ( ViSession Vi, ViInt32 BufferSize, ViChar Buffer[], ViInt32* ReturnCount );
I just replaced the ViInt64's with ViInt32's in the header.  Is this going to cause me a problem?  I'm not sure I even need this functions but they may be used internally in the driver set?
Appreciate your assistance!
(5,189 Views)
Hey zaius,
You should be alright with your current configuration, you just have to keep in mind ViInt32 will give a 32-bit integer as opposed to a 64-bit one. If you would like to use ViInt64, you'll need to upgrade to a newer version of LabWindows/CVI. Hope this helps.
Paul C
(5,161 Views)
Thanks for the input sir.  I'm a EE recently thrown into the software world.  What about driver implementation needs a 64 bit integer? 🙂
(5,147 Views)
If you were using 64-bit integers on a 32-bit machine, then that means it would take two CPU process cycles for the 64-bit integer to be operated on. This comes from the natural abilities of a 32-bit vs 64-bit computer. Higher bitness can give higher resolution integers and there are some memory improvements from using a 64-bit computer as well. You can check out this article for some more details on 64 vs 32-bit operating systems.
https://www.ni.com/en/support/documentation/supplemental/09/using-national-instruments-products-on-3...
Paul C
(5,113 Views)
