LabWindows/CVI
LabWindows 2010 Compatibility with LabView RT 2011
Tom,
At this point, we are going to have to do some more advanced debugging to figure out what is going on. Would you mind if I requested to recover your email from our forum database so that I can contact you directly?
Message 21 of 23
(1,259 Views)
Not a problem.
Tom
Message 22 of 23
(1,258 Views)
I wanted to update this thread because I think other people have ran into this issue and the conclusion here is ambiguous.
If you are using CVI 2010 with LV 2011 RT, then you will run into the issue discussed in the first page of this thread and detailed again in the following KB:
http://digital.ni.com/public.nsf/allkb/AB711D9CCE65CB1B86257975006B3E81?OpenDocument
Tom actually had an unrelated issue that we solved offline and should not affect other users.
If the information in the KB does not resolve your issue, please create a new thread and reference the KB article.
Message 23 of 23
(1,156 Views)
