LabWindows/CVI
LabWindows 2012, linking Windows C Run Time library fails
I need to build a LabWindows application with linking prebuilt libraries (.lib) that were built with VS2010.  One of the .lib libraries is using function in fcntl.h that is not included in the LabWindows C run time environment. Is there a way to force LabWindows to use VS2010 Windows C Run Time environment?  I tried to import msvcrtd.lib from VS2010 but I get the following error:
3 Project link errors
 Bad header encountered while reading external module: 'f:\dd\vctools\crt_bld\SELF_X86\crt\prebuild\build\INTEL\dll_obj\tcmap\_mbccpy.obj'.
 Aborted load of member "f:\dd\vctools\crt_bld\SELF_X86\crt\prebuild\build\INTEL\dll_obj\tcmap\_mbccpy.obj" from library "c:\Users\ahallajp\Documents\LabWindowsProjects\VS2010\msvcrtd.lib".
 Aborted load of library "c:\Users\ahallajp\Documents\LabWindowsProjects\VS2010\msvcrtd.lib".
(3,296 Views)
Hi ah80,
Instead of forcing LabWindows/CVI to use the Visual Studio 2010 C Runtime Environment, have you tried including the fcntl.h in your LabWindows/CVI application?
(3,261 Views)
I'm getting a link error (undefined symbol) which indicates the definition of functions are missing. Including the fcntl.h header file will not solve the issue. I need to link a library that contains the definition of the functions in fcntl.h
I did try to use the DLL import generation capability in labwindows in order to create a .lib library from the Windows C Runtime DLL hoping that might link successfully but that didn't work either. There are syntax in windows header files that labwindows compiler does not recognize.
(3,257 Views)
Hi ah80,
Do you have the source code for these libraries built with VS2010? Would it be possible to recreate them in LabWindows/CVI?
Also, would you be able to provide some information on the background of these libraries? Were they created in ANSI C?
(3,232 Views)
No, I don't have the source code to the VS2010 libraries. They are third party libraries provided by a vendor and they don't distribute the source code.
Update on the issue:
I tried experimenting with newer versions of LabWindows and I was finally able to link the VS2010 C run time library using LabWindows 2017.
(3,203 Views)
