LabWindows/CVI
LabWindows CVI 2020 Application Error 0xc000041d
I migrated fom CVI2019 to CVI2020.
Now I have often the problem, that the IDE stops working.
Switching between the Tabs is freasing and a few moments later the IDE is crashing.
I am using CVI2020 under win11
Inside the System Event Protocol I have the error logs.
- <EventData>
  <Data Name="AppName">cvi.exe</Data>
  <Data Name="AppVersion">20.0.3.49152</Data>
  <Data Name="AppTimeStamp">642a845c</Data>
  <Data Name="ModuleName">KERNELBASE.dll</Data>
  <Data Name="ModuleVersion">10.0.22621.2861</Data>
  <Data Name="ModuleTimeStamp">9e57f18c</Data>
  <Data Name="ExceptionCode">c000041d</Data>
  <Data Name="FaultingOffset">00149392</Data>
  <Data Name="ProcessId">0x1220</Data>
  <Data Name="ProcessCreationTime">0x1da4eca7b93c6e6</Data>
  <Data Name="AppPath">C:\Program Files (x86)\National Instruments\CVI2020\cvi.exe</Data>
  <Data Name="ModulePath">C:\WINDOWS\System32\KERNELBASE.dll</Data>
  <Data Name="IntegratorReportId">a5bc121b-d710-45af-baaa-d39e05c61ef2</Data>
  <Data Name="PackageFullName" />
  <Data Name="PackageRelativeAppId" />
  </EventData>
(1,594 Views)
I can't help much but that's usually a job for ConfigCVIlogging.exe
(1,560 Views)
