LabWindows/CVI
LabWindows/CVI 2020 & Win10 - non debuggable thread caused a 'Unknown' fault at adress....
Dear LabWindows experts,
following issue has been reported a couple of times in the forum, however it still appears to be an actual problem:
I have a test code:
void main(void)
return;
System environment:
- LabWindows CVI 2020 - Full Development System , Version: 20.0.0 (49152)
- Windows 10, 64 bit
LabWindows is a fresh installation ... no update from a previous version.
The PC has also not seen any previous LabWindows installation before.
Running the code above ends up in the follwoing:
  FATAL RUN TIME ERROR:
  Unknown source position, thread id 11756:
  A non-debuggable thread caused a 'Unknown' fault at adress 0x6CFD1982.
  No source line information is available.
I have read this post.
https://forums.ni.com/t5/LabWindows-CVI/FATAL-RUN-TIME-ERROR-Unknown-source-position-thread-id/m-p/3...
At the end of the post a patch is mentioned to fix the error, however there is no link to the patch.
Question: Is the patch (12-22-2016) included in LabWindows/CVI 2020?
If not: How to find/install this patch?
If yes: How to fix the error?
Thank you,
Philipp
(3,412 Views)
Hi
Did a test using your source code and did not get any errors. So I guess it is fixed in CVI2020.
Jan
(3,336 Views)
Thank you for the feedback.
Do you also use Win10?
Best Regards,
Philipp
(3,331 Views)
Yes
OS Name Microsoft Windows 10 Pro
Version 10.0.19041 Build 19041
System Type x64-based PC
Processor Intel(R) Core(TM) i9-9920X CPU @ 3.50GHz, 3504 Mhz, 12 Core(s)
(3,326 Views)
The bug you are referring was happening with the original 2015 RTE on WIn10 Anniversary Update and was corrected by a patch ont he RunTIme Engine itself. See this complete discussion.
I haven't observed it with the RTEs 2015 (patched), 2017 and 2019 running under several Win10 releases. I have not yet installed CVI2020 and its RTE so I cannot discuss about this item, but maybe some other user can comment if they have 2020 installed?
(3,272 Views)
Thanks for the reply.
I tested it also today on another PC, with this configuration:
- Win10, 64bit
- Labwindows/CVI 2017, FULL Development System, Version 17.0.0 (295)
I do get the same error.
Maybe an important note?
On both PC's is also the Vision Development Module installed.
BR
(3,260 Views)
Following this thread:
Solved: Re: CVI executables causes Access Violation 0xC0000005 on Windows 10 Anniversary Update. - N...
The solution at hand is to implement:
   SetSystemAttribute(ATTR_TASKBAR_BUTTON_VISIBLE, 0);
into the code. This prevents the error.
However this is just a workaround and not the fix for the error.
For this I understand a patch must be installed...I however do understand that the solution given was for
LabWindows/CVI 2015 SP1...I am running LabWindows/CVI 2020.
Best Regards
(3,235 Views)
