LabWindows/CVI
LabWindows/CVI 6.0, Compiling error when including 'mil.h' (Matrox Image Library): syntax error;found identifier expecting ';' at code line: 'typedef __int64 MILINT64'
I got this problem after including 'mil.h' in my labwindows project. Is there any additional header file I should include?
(3,498 Views)
Good news and bad news. The bad news is that you are getting this error because CVI 6.0 doesn't support 64-bit integers. There is no great way around this unfortunately without quite a bit of effort on your part.
The good news, is that the new version of CVI, 7.0 just released last week, now supports 64-bit integers. It is also include a ton of great improvements to the development environment that are well worth the upgrade.
Best Regards,
Chris Matthews
(3,498 Views)
