LabWindows/CVI
LabWindows/CVI 8.0.1 to Visual Studio 2013
I have LabWindows/CVI 8.0.1 and Visual Studio 2013.  I'd like to convert a project from CVI to VS.  The wizard to do so ( in VS ) isn't present and I can't install it as the CVI installer looks for VS 2005 ( only? ).   It states you must have VS 2005 or higher installed but I'm guessing since the CVI 8 installer had no concept of VS 2013 when it was released that it doesn't realize 2013 is newer than 2005.  Is there a work-around, a patch that updates the wizard, etc. I can use?  Thanks.
-G-
(4,605 Views)
Judging from this, I don't think NI has a newer version of this tool:
http://forums.ni.com/t5/Measurement-Studio-for-VC/Convert-project-from-LabWindows-CVI-to-Visual-Stud...
(4,574 Views)
That's what I am thinking.  The work around of converting to 2005 and then upgrading is fine IF you have 2005 installed.  But since I don't that work around is no solution.  Thanks for the post.
-G-
(4,562 Views)
