LabWindows/CVI
LabWindows CVI 8.0 is extremely slow when run in debug mode
I have three nested loops mostly of array assingnemnts, when run in debug mode, it works eventualy but it is extremely slow
Are there configuration options, that I need to set for the debugger to go faster?
I am running WinXP service pack 2
Message Edited by atjerome on 03-24-2008 05:00 PM
(3,540 Views)
I would check if you have a number of watchpoints that are set to update continuously or break on change.  This is often the source of "unexpected" slowness while debugging.  Also note that there is a splitter in the watch window -- sometimes  watchpoints can become hidden when this splitter gets moved all the way to the top.
Mert A.
(3,517 Views)
