LabWindows/CVI
LabWindows/CVI Idea Exchange
Hi userIECS,
This post seems to suggest that the functionality won't be moved over to 64 bit systems because it's really old technology that could run into security restriction problems. Take a look at the post as it references a possible solution using the VISA API.
Message 11 of 37
(10,999 Views)
Thank you for answer, I'll try with VISA API.
Best regards.
Message 12 of 37
(10,992 Views)
My query is, In single graph taken in the uir of labwindows , Is it possible to integrate two graphs
Eg: I need to integrate V versus T and C versus T within the taken single graph from the palette
Message 13 of 37
(10,574 Views)
Hello snoopy, please don't spread a single question across multiple threads: yu have already created a new discussion and this is the right way to do; let's follow the discussion here.
Moreover, this thread is to announce and comment the LabWindowsw/CVI idea eschange, an area where suggestions for new improvements can be posted for everyone to comment or support them if considered useful. Requests for clarifications on existing functionalities do not pertain the the idea exchange.
Message 14 of 37
(10,567 Views)
 i  am using sqltoolkit 2.0  &  OS window 7 , when i am uploading  the data to database .   then i am getting this error.
Message 15 of 37
(10,498 Views)
Hello mukesh121, please don't spread a single question across multiple threads: you have already created a new discussion here and this is the right way to do.
Moreover, this thread is to announce and comment the LabWindowsw/CVI idea exchange, an area where suggestions for new improvements can be posted for everyone to comment or support them if considered useful. Requests for clarifications on existing functionalities do not pertain the the idea exchange.
Message 16 of 37
(10,486 Views)
I have used LabwindowsCVI for 5 years.From 09 to 2013 sp2.It's a good software for using.But for so many versions,I also found some questions about the software which is not convenient for user.I hope CVI authors can fix those.
1\When there are many files in editors,I must use x to close files.2.png,I hope we can use in such way,1.jpg
2\When I distributed the files,use cvi tools,it will build a very large pack.SO usually I only take the .dll to my software.Whether we can get the small package when I use the distribution.
3\When I use the right click,"GO TO DEFITION "to see a varible,But I'cant go back.I muse open the file to find.Where I can go back to click a button,just like
the picture come from Keil for mcu.I think the editor has many advantage which we can learn.Thanks,hope cvi better.
Message 17 of 37
(9,634 Views)
Hello zhangxing,
this thread is to announce the CVI Idea Exchange board, where you can post your suggestions to improve this beautiful product. I suggest you to take a look to that board: you'll find plenty of useful ideas that you may want to support adding kudos to the most interesting to you. You will find for example this suggestion that addresses you question #2.
As per your other questions, you're right that at present those features are not present in the IDE, with the exception of Windows>>Close all menu function, so feel free to post your suggestions there and get kudos / comments from all other users.
Message 18 of 37
(9,616 Views)
1. There is a "Close Other Tabs" item in the menu that appears when you right-click on the editor tab.
3. There isn't a toolbar button to 'go back' after you go to a definition or browse to a reference, but there is 'Go Back' menu item in the Edit menu > Go To submenu. You can also use the <Ctrl+G> keyboard shortcut, or the right-click menu of the source editor.
Message 19 of 37
(9,609 Views)
Uhu! I missed those shortcuts when versions changed!
Message 20 of 37
(9,744 Views)
