LabWindows/CVI
LabWindows CVI Opening existing Excel file and writing a float value to a specific cell
I am trying to open an existing Excel file in CVI and write to a specific (not a range) .
I have tried:
error = ExcelRpt_ApplicationNew(1, &applicationHandle);
ExcelRpt_WorkbookNew(applicationHandle, &workbookHandle);
ExcelRpt_WorkbookOpen (applicationHandle, "TestBook.xls", &workbookHandle);
ExcelRpt_GetWorksheetFromName (workbookHandle, "Sheet1", &worksheetHandle);
ExcelRpt_SetCellValue (worksheetHandle, "F2", ExRConst_dataDouble , pin5_value_1);
The above will open a new file (not the TestBook.xlsx file) and write to the proper cell with the correct information
Then I tried the example in "excel2000dem" (error stuff removed)
Excel_NewApp (NULL, 1, LOCALE_NEUTRAL, 0, &ExcelAppHandle);
Excel_SetProperty (ExcelAppHandle, NULL, Excel_AppVisible, CAVT_BOOL, appVisible?VTRUE:VFALSE);
MakeApplicationActive ();
excelLaunched = 1;
Excel_GetProperty (ExcelAppHandle, NULL, Excel_AppWorkbooks, CAVT_OBJHANDLE, &ExcelWorkbooksHandle);
GetProjectDir (fileName);
strcat(fileName, "\\TestBook.xlsx");
Excel_WorkbooksOpen (ExcelWorkbooksHandle, NULL, fileName, CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL,
     CA_DEFAULT_VAL, &ExcelWorkbookHandle);
Excel_GetProperty (ExcelAppHandle, NULL, Excel_AppSheets, CAVT_OBJHANDLE, &ExcelSheetsHandle);
Excel_SheetsItem (ExcelSheetsHandle, NULL, CA_VariantInt(1), &ExcelWorksheetHandle);
Excel_WorksheetActivate (ExcelWorksheetHandle, NULL);
The above worked get at opening the existing file but then I couldn't write to the correct cell (or any cell)
I tried:
ExcelRpt_SetCellValue (ExcelSheetsHandle, "F2", ExRConst_dataDouble, pin5_value_1);
and a couple of other items but to no avail.
Can anyone help with this issue?
ExcelRpt_SetCellValue (ExcelWorkbookHandle, "F2", ExRConst_dataDouble, pin5_value_1);
(434 Views)
One possible reason is that ExcelSheetsHandle is the handle to the collection of all sheets in the file while ExcelWorkbookHandle is the handle to the whole file: none of them is the handle to the active sheet you are working on. Moreover, I don't think you can mix functions from Excel Report instrument and from base Excel Object Library in the same function (but I may be wrong on this, I never used Excel Report instrument).
If you want to follow the path of Excel2000dem example you could create and activate a single cell range and then write the value you want to it, more or less the way done in WriteDataToExcel (), case 2 of the example.
(407 Views)
