LabWindows/CVI
LabWindows CVI (demo-version) - DLL not running any more
i created a working DLL (for an ivi-driver) with CVI which used to work without any problems 2 years ago.
Today i wanted to re-use the DLL but it didnt work any more. The dll-file wasnt recompiled it the original file from 2 years ago.
Now the question is: Is the demo-restriction also compiled into the DLL, so that the DLL is also not running any more after the 7 days?
When i open the dll with editor then there can be found some textmessages which sound like this.
Thank you for the answer
(3,208 Views)
you will have to create a dll with an activated CVI license to use it after the eveluation period. I found several (also internal) requests which point to this solution. Here are some links with similar problems:
http://forums.ni.com/t5/LabWindows-CVI/CVI-2009-RTE-eval-mode/m-p/1041360?requireLogin=False
http://forums.ni.com/t5/LabWindows-CVI/CVI-Expired-Message/td-p/536078?view=by_date_ascending
Best Regards,
Matteo
NI Germany
(3,093 Views)
