LabWindows/CVI
LabWindows/CVI not started with message "The attribute value passed is not valid" - please help me!
Colleagues,
Today when I tried to start CVI I've got the message "The attribute value passed is not valid" (coming immediately after CVI splash screen). Then CVI closed.
I have uninstall CVI, then install it again. The message still here. CVI not starting.
I guess it happened after installation Paragon Partition Manager (already uninstalled), but not sure.
How can I continue working with CVI? Any suggestions? Something bad in the registry?
Thank you,
Andrey
PS
I don't like idea with reistall Windows completely...
(3,833 Views)
Hello Andrey,
If you haven't yet, take a look at all the posts in this thread to see if you're in the same situation. If that's not it, then let us know and we'll figure out how to proceed.
Luis
(3,825 Views)
Thank you, Luis, you saved lot of time for me!
Exactly what I needed. And the problem was with the value of ProjectWindowSplitter1. The value was too big. Now it works.
Seems to be small bug here, isn't?
best regards,
Andrey.
(3,822 Views)
Yes, there is a bug, as the other thread discussed. It's being fixed.
I'm glad it's working now!
Luis
(3,816 Views)
