LabWindows/CVI
LabWindows/CVI on Windows CE or XP embedded.
Would my software written by LabWindows/CVI 5.0 run under Windows CE or XP embedded.
(3,697 Views)
It definately won't run in WinCE. I'm not sure about XP embedded since I haven't worked with it. It depends on what from the core Windows SDK is not available under XP embedded.
Best Regards,
Chris Matthews
(3,697 Views)
LW/CVI 5.0 has not been tested on any XP system. The earliest version supported by XP is LW/CVI 6.0. It may work, but it is not 100% certain. I would reccomend updating, if you have no other operating systems.
Derek
(3,697 Views)
