LabWindows/CVI
LabWindows DLL with GetDateTimeElements
I am integrating TestStand, LabWindows, and LabVIEW. I need to use the LabWindows function GetDateTimeElements. I prefer to call it directly from TestStand. Is there a DLL that has this function in it? If so, can you point me to the name and location?
Thank you for your help.
(5,580 Views)
Actually, I am trying to find a function to get the day of the year for a vendor supplied function which I call from TestStand. Looking back, GetDateTimeElements does not provide that. Any thoughts on how I can get that day?
(5,552 Views)
Hello BillSimmons,
By "day of the year" you mean from 1-365?
Carmen
(5,540 Views)
Did you check inside the cvirte.dll file?
Probably it includes most of the CVI library functions, if not all...
S. Eren BALCI
IMESTEK
(5,529 Views)
Thank you for the pointer.
I found the time and localtime functions in there which is what I need. Although, when trying to call them from TestStand, it indicated that the DLL did not contain the parameter information needed by TestStand. No problem as I looked up the parameter information from the time.h file. The time function works fine in TestStand. I cannot seem to get the locatime function to work, in TestStand, because a structure is returned.
#ifndef _TIME_T_DEFINED
#define _TIME_T_DEFINED
#ifdef _NI_mswin64_
typedef __int64 time_t;
#else
typedef unsigned int time_t;
#endif
#endif
struct tm {
    int tm_sec;
    int tm_min;
    int tm_hour;
    int tm_mday;
    int tm_mon;
    int tm_year;
    int tm_wday;
    int tm_yday;                                     <-----   Day of Year
    int tm_isdst;
struct tm * CVIANSI localtime(const time_t *);
I will ask the TestStand group if anyone has worked with this.
(5,500 Views)
