LabWindows/CVI
LabWindows Driver Installation
I installed LabWindows/CVI 7.1 and wasn't sure if I needed certain drivers, so I didn't install them. Now, I'm thinking I do need them. Do I need to completely re-install CVI or can I install the additional drivers only.
(3,278 Views)
Hello Mrbean (nice name, btw),
You do not have to completely reinstall CVI, you can go to Add/Remove Programs from the Control Panel. From there, navigate to National Instruments Software >> Change >> LabWindows/CVI >> Modify. Then you can select which additional components you would like to install.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(3,273 Views)
