08-01-2005 05:01 AM
08-01-2005 05:20 AM
08-02-2005
05:59 AM
- last edited on
07-08-2025
02:46 PM
by
Content Cleaner
Peter, If this has been posted elsewhere, please point to that thread so that I can give a complete solution to the community. Firstly the Instrument I/O Assistant is never used with DAQ products, this is for GPIB/Serial type instrument control. You have probably got this mixed up with the DAQ Assistant, especially if it isn't there. The DAQ Assistant is part of the DAQmx driver and this must be installed before it can be used. Very recently DAQmx 7.5 was released which now allows you to use the DAQ Assistant in conjunction with a USB-6009 or USB-6008. Prior to this, DAQmx Base was used with the USB products. Check out the following links for the 7.5 download and some additional information.
Further information
P.S. In normal operating conditions the LED located on the device will blink, and is not expected to be illuminated constantly.
08-02-2005
06:04 AM
- last edited on
07-08-2025
02:47 PM
by
Content Cleaner
