LabWindows/CVI
Labview LvLib to Dll
I have a application runs on Labwindows/CVI , as a latest addition ended up with vendor only provides LVlib as a driver file to control his hardware , can any one please help me , how to convert Lvlib to a DLL? or any other alternative to use Lvlib in Labwindows/CVI?
your help on this is very much appreciated!!!
Bharathi
(2,493 Views)
Well in order to do that you first need to post the LabVIEW library with all its VIs. Put everything in a zip file and also add some documentation about the function. Then attach that to your reply. The manufacturer did send you some Programmer Reference manual, did he?
Depending on the number of functions this library exports this may be however a major effort that is not easy to provide for free. So bear with us if you get the, sorry to much work reply.
Rolf Kalbermatter  My Blog
(2,436 Views)
