LabWindows/CVI
Labview Windows: Byte-order issues (little and big "endian")
Can someone explain or answer the following:
1) When Labview was ported to Windows (or intel-based systems) why
didn't they change the byte-order for variable storage to be
compatible with the low-byte/high-byte order that was (is) the
standard for representing numbers on systems using Intel-based CPU's
2) Is there a "switch" or meta-command or some other statement for
telling Labview-windows to use low-byte / high-byte order when
compiling or running a labview program?
3) Is it just me, or does National Instruments fail to mention or
discuss this glaring incompatibility (in such terms) caused by this
byte-order issue in it's various on-line documents / faq's /
Knowledgebase?
(4,632 Views)
There is a shipping document with LabVIEW help that discusses this called LabVIEW Data Storage Formats. There is also many things in our Knowledgebase about this. This was also discussed a while ago in the LabVIEW forum on this site, you can read that discussion here.
Best Regards,
Chris Matthews
(4,632 Views)
> (etc)...
It seems that the thread you mention was not concluded satisfactorily
for Greg McKaskle or Eric (the OP).
What I read from it is that people have to impliment cumbersome and
in-elegant solutions to overcome the bone-head decision by National
Instruments to keep the Motorola/Apple byte-order sequence when LV was
ported to Intel-based computers running Windows.
Dumb Dumb Dumb.
(4,632 Views)
One of the drawbacks of designing LabVIEW for multi-platform is we can only have one of these formats and still have the files and VIs transferrable between platforms.
(4,632 Views)
Okay, but how about an easy conversion vi so data files can be saved in a format that other windows programs can read?
(4,632 Views)
