LabWindows/CVI
Labwindows 2012 Localization Error
I'm getting a crash of the Localization utility trying to translate my application in labwindows CVI 2012.
When i enter 1 letter in "local language" an error occure and the localization Utility close.
You can observe the error in the added screenshot.
Does a patch exist to resolve this error ?
G. Lacroix
(3,011 Views)
This appears to be a known issue on the localization utility in CVI 2012 and 2012SP1 (CAR 432526😞 if this is your situation, there seems not to exist a patch. That issue is declared solved in 2013SP1.
(2,985 Views)
Loading the .lwl file seems to be a workaround.
No more crash with that.
G. Lacroix
(2,978 Views)
