LabWindows/CVI
Labwindows CVI / DotNet version compatibility
I need to create a dot net controller with CVI from a dotnet (V4.8) dll.
I tried with CVI 2017, but I have the error "The attribute value passed is not valid".
Do you know if the CVI version is the fault?
Thx fot help
(1,559 Views)
Hello GuillaumeSteinling,
Did you check this article before? Try to go through that it might be helpful in this case.
Regards)
(1,464 Views)
