LabWindows/CVI
Labwindows/CVI and Android
I work in Labwindows/CVI on Windows XP for the moment, I developpe a software and I would like to know if it will be possible to make a software, the same that this one to run on Windows, which runs on Android please ?
My software uses a SQL database (SQL Server) and an OPC Server (Phoenix Contact).
If it's possible, how can I do to create this application and install on a tablet for example?
I just know that a "NI LabWindows™/CVI Run-Time Module for Linux" exists, but I don't know if this module allows me to install my software on a tablet...
Thanks.
Bye Karine
(5,208 Views)
I don't think this is possible.For two reasons:
Android usually runs on ARM processors. But CVI only supports generating code for x86 compatible processors.
And parts of your software ( like SQL Server) depend on using Windows as OS.
(5,183 Views)
In addition Android programs are normally written in Java, which has nothing
to do with CVI. But I read a tutorial some time ago that showed how to
compile C for Android. So at a very basic level of a pure ANSI C program
with no (or duplicate) user interface, it is possible.
Guillaume Dargaud
http://www.gdargaud.net/
(5,176 Views)
