LabWindows/CVI
Labwindows Code for NI-4060/4070 measurements
I have a  trouble reading from the DMM. I have conncted my DMM to the points where I want to measure the voltage difference(1.7mv). When I used the DMM soft front panel, I can read the values precisely,even at higher range.
But I tried to read the value from TestStand and Lab windows. the value keep changing every time I make the measurements. When I loop the measurement step, it returns values ranging from 4.8mv to -0.5mv and its quite a lot of difference from the actuval value(1.7mV). I have even tried to use the recommended/default sample time -1, but of no use. The same thing happens in Labwindows interactive execution too.
Is there anything I can make my code better to get accurate measurements same as like from the front panel measurements.
Attached is my Labwindows code.
mama007
(2,945 Views)
This is a duplicated thread, please see the link below for discussion.
http://forums.ni.com/ni/board/message?board.id=80&message.id=704
Rob
National Instruments | Northern California
(2,924 Views)
