LabWindows/CVI
Labwindows DLL and Excel VBA
Here is XLS and DLL that work.  Click the blue button to activate the VBA, or run directly from the VBA screen.
Message 11 of 13
(2,341 Views)
I tried your dll and the VBA script and I keep getting an error.
We are still looking into the issue with passing a struct with a CVI 2013 dll.
Jesse S.
Message 12 of 13
(2,328 Views)
Hi ruskin1,
I was able to run your VBA script from Old_DLL.zip, but the dialog returned an error "data\WW5DB.wdb".  Do you still have the source code for ww5_DLL.dll, and if you do, would you be able to provide that?  I used the source you provided for Test_DLL_VBA.prj, built it in LabWindows/CVI 2012, and ran TESTCVI_DLL_VB.xls in Excel 2010, causing a crash.
Can you verify that you are currently able to use a version of Test_DLL_VBA.prj, compiled in LabWindows/CVI 2012, which does not crash Excel?
Daniel
Daniel Dorroh
Message 13 of 13
(2,318 Views)
