LabWindows/CVI
Labwindows cvi 2010 sp1 Device drivers
Hi all
  I am trying to install cvi 2010 sp1 and it is asking for the Device Drivers for the program, where can I find the drivers for the sp1.
To finish installing
I have some older drivers but what is the latest for sp1
Thanks in advance
(3,306 Views)
Device drivers are separate software products.
They are not tied to a version of CVI, and you dont have to install device drivers for a complete CVI installation.
In the installation windows, you can choose to not to install the drivers.
Later you may insert the device driver DVD and install whichever driver you want.
S. Eren BALCI
IMESTEK
(3,298 Views)
Hi Iriddick,
You can choose to not install the Device Drivers with CVI and you will not get that window.  You can also cancel installing the Device Drivers without cancelling the CVI installation.  If you would like to install the Device Drivers, you can find the latest version by searching for "device drivers" at the ni.com main page.  The current latest version is the NI Device Drivers 2011.08.
Brandon V.
Applications Engineering
www.ni.com/support
(3,276 Views)
