LabWindows/CVI
Labwindows in openmosix
Hello!
I have the following problem.
I successfully developed and compiled a LabWindows project in linux  with the run-time module for linux. The distribution I'm using is openmosix 2.4.24 because I would like to run the project on a PC cluster. The problem is that the process running on a node of the cluster are not migrated to other nodes, or, when they are migrated, they cause a segmentation fault.
I think that it must work because once I was able to run four different project instances on four different nodes without any problem. Unfortunately that situation did not repeat anymore.
Someone can help me?
Thank you in advance,
Lory
(3,281 Views)
Have you installed the LW linux runtime on all the nodes ?
I'm thinking of the dynamic libraries in particular.
Have you tried doing static compilations ?
PS: when is the next version of LW for Linux coming out, it's way past due ?
Guillaume Dargaud
http://www.gdargaud.net/
(3,242 Views)
